Zero Pressure Drop vs. Time in Monitoring Well. What does it tell me?
I've always been an air guy so this is new to me. I'm trying to determine negative pressure for a low flow (10 to 30 cfm) SVE system. Pilot data show zero pressure drop vs. time in the monitoring well (25 ft from extraction point) except fo an instantaneous drop of 1 in. H2O at the initiation of the test. The pressure remains 1 in. H20 for the remainder of the 4 hour test. This seems to tell me that there is little resistance within the radius of influence (sand/gravel matrix under an impervious concrete surface). Flow rate at the extraction point is 85 cfm.
Essentially, I want to use this data to approximate what the negative pressure will be at the extraction point in the 10 - 30 cfm range so I can properly size my equipment. I'm considering a natural ventilator if I can convince myself and prove to my client that the negative pressure at the extraction point is negligible. Thanks for the help.
Wayne
Wayne
RE: Zero Pressure Drop vs. Time in Monitoring Well. What does it tell me?
The way your post is written, it sounds like you did one constant-rate test during the pilot. Is that right?
Chapter 4 of the Army Corps' engineering manual for SVE systems is a good place to start for learning about the various tests that should be run in a pilot.
http://1
What are the characteristics of the extraction well (screen length in vadose zone, diameter, vacuum during test)? Pilot tests can help you determine air permeability and thus the radius of influence (which depends on how you define it). The Army Corps manual has provides input on the theoretical ways to determine this.
Doing step tests can tell you how the flow rate at the extraction well affects the vacuums in the extraction well and the monitoring well. Theoretically, you'll eventually reach a limit on your air flow as vacuums increase (if graphed it will look like a log curve).
I've done a lot of pilot tests and calcs before going in the field and every time there is a variable you don't think about until you do it (wet soil, bad screen installation). I've seen a pilot test in soil that theoretically should have had a high radius of influence but didn't and later they found a large void from buried rip rap about 10 feet from the extraction well. The monitoring well was about 30 feet away and didn't read any vacuum not matter how high they increased the flow rate.
