part navigator formatting
Is there a way to format how the steps look in the part navigator? I'm trying to setup a master sketch for our product and I was using separate sketches for each component and renaming the sketch to component name. The trouble is all the steps have (Sketch (4) "Sketch_000:Shaft"). Where "Shaft is all I concerned with.
RE: part navigator formatting
Rather than naming your sketch in the part navigator, rename it within the sketch environment. Sketch_000 is the name of your sketch, you can change this to shaft, then it will appear as Sketch (4) "SHAFT" in the part navigator.
Gets you a step closer to what you wanted.
That helps out thanks.
