NX7.5 Customer Defaults ~ Drafting Standard
We are moving up to NX7.5, and I am tweaking our customer defaults.
I needed to come up with a customized drafting standard, which I saved under a unique name.
I can access this drafting standard from my computer, and it shows up in my "Tools -> Drafting Standard" list,
but it does not show in the NX sessions of the other users that loaded the customer defaults.
I opened up the .dpv file and saw that the customized drafting standard is in there.
How do I make this customized drafting standard available to the other NX users?
RE: NX7.5 Customer Defaults ~ Drafting Standard
2) Is the .dpv file shared with all users?
3) Does the .dpv file have different sections for local/user changes versus system-wide changes?
Ben Loosli
2) Yes, I put the .dpv file in a location where others can get to it.
3) I really don't see in the Customer Defaults where I can make those changes. All I see on top of the menu is a "Defaults Level" menu with only one "User" choice in there.
I have a feeling that I need special privledges for this.
you need to set the UGII_SITE_DIR variable to point to a location that everyone can access. Then you can have SITE defaults in the customer defaults.
if you want, post an NX log file and I can make more sense of how your system is setup
Anthony Galante
Technical Resource Coordinator
NX4.0.4MP10, NX5.0.0->5.0.6, NX6.0.0->NX6.0.5, NX7.0.0->NX7.0.1 & NX7.5.0.32-> NX7.5.4.4, NX8.0.0.25
