Micro-zipper or zip-lock technology
Hi!
Just a quick question on zipper (or alternative) technology:
I need an un-zip/re-zip a long volume the size of a shoelace (tiny). I'd like to find a reliable means to do that- it could be a deformable ziplock type closure or a toothed zipper type closure, or something else, but the scale needs to be as small as possible.
It is not essential that it be air-tight, but that would be a plus, the tighter the better. Flexible is also good, but not critical.
Of course a stronger seal is preferred, but I realize I can't have my cake and eat it too.
Minimal size trumps all other concerns in this case. Thanks in advance for any suggestions!
-k
-k
RE: Micro-zipper or zip-lock technology
Now put the cloth tube thing, in the Lego man's hand, and put a cylinder through the tube.
Now make it fit your scale, and use a flexible single strand piece of wire or plastic.
The hand is on one end, the cloth loop on the other. Roll it together in a circle and install the wire. Adjust the surface condition of the cloth loop (rubberize, or use different material) if you want it to be airtight.
Side view looks like this o------C
http://www.zippertubing.com/
Mike Halloran
Pembroke Pines, FL, USA
1gibson: thanks for the idea- I think I get it, but this needs to separate and reunite in the middle- similar to two "shuttles" on the same zipper (eg.a jeep wrangler window- but on a much smaller scale)
Mike:
Some of the products at that link constitute the closest thing I've seen yet! Definitely will give them a call and find out more! I guess 50+years isn't enough time for me to discover 'em! :)
thanks!
-k
I looked very quickly and didn't see anything on your small scale in the standard line of products, but it's worth giving them a call I suspect.
