Tappet anti-rotation scheme
I hope I'm not violating a forums rule by posting "just for fun"?
This ia an Iskenderian Cams ad from Mar '58. Although I usually enjoy puzzles, I'm at a loss to visualize "automatic, self-locking keys" that require merely "dropping the lifters into place".
These ads didn't run long- way less than a year, if I remember correctly, so I'm guessing the scheme wasn't flawless.
Umm... disregard above, until I figure out how to upload the image!
RE: Tappet anti-rotation scheme
I had a very early set of Isky roller followers that had blades off the side of the follower that had a tongue and grove principle to stop rotation. I ran them for 20 odd years and sold them in a running engine, so they obviously worked. You would see them from a top view or a side view with correct orientation.
Pat
See FAQ731-376: Eng-Tips.com Forum Policies for tips on use of eng-tips by professional engineers &
http://eng-tips.com/market.cfm
for site rules
Since we're talking about roller followers, wouldn't a tiny bit of caster be adequate?
Bill
I can't see enough castor being possible to accommodate the shift in contact point as the cam profile strikes the roller as the cam rotates. I have never measured it, but it seems like it could go something like 45 deg shift from the axis of the follower on an aggressive profile like a concave or unversed flanked cam.
Pat
for site rules
Norm
Here's a couple of Isky lifter patents from that time period.
Pat
for site rules
Brian,
