Workoffset G54, G55 outputing from post builder every operation ?
i am in the process of working the kinks out of a DIY post i've made for a BOSCH cc120 used to control a router.
i use G54 - G57 as references for the 4 corners of the machines bed, and regularly use 54 and 55 when flipping a sheet over to machine on both sides.
i have a custom command in my post to output the fixture offset +53 and to stop the machine and move to a position for easy loading.
the custom command is placed in start of operation.
problem is this outputs the reference in between every operation, which is quite annoying when on G55 !
i have tried puting the whole thing in to something like: "if {$workoffset != [expr $mom_fixture_offset_value +53]} type s
#Set work offset & stop machine to alow for part repositioning at G55 and above
global mom_fixture_offset_value
global workoffset
global workoffsetchange
set workoffset [expr $mom_fixture_offset_value +53]
if {$workoffset >= 55} {
MOM_output_literal "M05"
#Stop spindle
MOM_output_literal "M09"
#Raise Head
MOM_output_literal "G53"
#Switch to MCS
MOM_output_literal "G0X1220Y1220Z0"
#move to loading postion
MOM_output_literal "M55"
#UnClamp Right
MOM_output_literal "M57"
#UnClamp Left
#MOM_output_literal "M51"
#VacPump 1 off
#MOM_output_literal "M53"
#VacPump 2 off
MOM_output_literal "M00"
#Stop program
MOM_output_literal "(FLIP/REPOSITION STOCK TO G$workoffset)"
#Operator message
MOM_output_literal "G$workoffset"
but im guessing the global variables are only global to the custom command, not the whole post?
anyone have a good idea of another way around this?
i would also like to change stop conditions, so rather than being >= g55, it will stop on the first offset change, allowing me to use G55 as the first side and G54 as the second side, purly for flexibility realy.
any help very appreciated.
global workoffset
#Stop spindle
#Raise Head
#Switch to MCS
#UnClamp Right
#UnClamp Left
#VacPump 1 off
#VacPump 2 off
#Stop program
#Operator message
RE: Workoffset G54, G55 outputing from post builder every operation ?
thank you very much, there fixture offset block was not all ready there, but it was easy enough to make one.
so that solves the first problem, but now i need to get the post to output something to the effect of the below output literals every time the offset changes except the first time. ( maybe the first time just a stop and operator message with the offset number)
#Stop spindle
#Raise Head
#Switch to MCS
#UnClamp Right
#UnClamp Left
#VacPump 1 off
#VacPump 2 off
#Stop program
#Operator message
can this also be done in block templates?
thanks a lot - at least now i am on the right track.
START OF PROGRAM COMMAND
set prev_offset 0
START OF PATH COMMAND
if {$offset != $prev_offset} {
code here
set prev_offset $offset
Add it to the initial move event so that the G54 is in a block with an X and Y set the output to forced. Add any other blocks you want after each tool change. Then you will get the desired output. Without writing a lot of custom commands. The fixture offset is a G code word that is available in PB.
John Joyce
N.C. Programming Supervisor
Barnes Aerospace, Windsor CT
NX6.0.5.3
that seems to be along the right lines, defining a global variable in the program start seems to make it truly global, which is what i was stuck with in my inital post.
i think i need 2 global variables for the start of path "IF" command to check. as there are 2 things that need to be true, before i want to output the list of stop / housekeeping commands
ie it needs to not be the first offset, and there needs to be a change in offset.
i think i will be able to work it out from here, thanks a lot for your help.
i will post the solution when its all working.
thanks again.
