Piston check valve
Piston check valve
Piston check valve
Hello all,
Can a small bore (1in) piston check valve be installed in both horizontal and vertical positions?
Thanks !!!
RE: Piston check valve
You'll have to pick one direction only. smile
Vertical has two possibilities, vertical flow up, vertical flow down.  Depending on precise design, vertical flow down may not give you the sealing you need at low reverse flowrates.  Vertical flow up usually does not present trouble.
Only put off until tomorrow what you are willing to die having left undone. - Pablo Picasso
Thanks BigInch.
