Smart questions
Smart answers
Smart people
Member Login
Join Eng-Tips now!
Join Eng-Tips
LINK TO THIS FORUM!
Just copy and paste the
code below into your site.
Partner With Us!
Partner Button
(Download This Button Today!)
Feedback
"...What you have done for people like me is immeasurably helpful."
Geography
marclegerstee (Mechanical)
18 Jan 12 10:42
Hi, can anybody tell me how can I see on the material cert. if the material is also usefull into the EU ? the material has been made in Japan, and refers only to the ASTM. and the material manufacturer has been certified acoording iso 9000.
micalbrch (Mechanical)
19 Jan 12 6:45
I'm not aware that there is a certain type of material certificate necessary for products used in the EU. The problem you might have is that your client will not accept certificates with ASTM references if your documentation towards your client lists ISO numbers. For what do you need the certificates? For internal use only or do you have to present them to your client?
19 Jan 12 11:02
micalbrch, Thanks for your reply, this material is part of a new boiler, so the mat.certs have to be submitted to our client on the end. and they have to be accepted by the PED requirements.
19 Jan 12 11:28
Aah, okay! That is a completely different background and yes, that can be a problem. My recommendation is the start a new post (with the PED background info) in the Boiler and Pressure Vessel Engineering forum. I beleive that you will get some valuable answers there.
XL83NL (Mechanical)
29 Jan 12 16:14
The PED plus it's guidelines will tell you what you need, or what you're 'required' to handover in case of a NoBo.
Mostly EN 10204 3.1 certs, maybe some 2.2 certs for bolting.
The cert's thus have to be EN 10204 3.1 (if it's a pressure vessel in cat I or higher acc PED).
PS: certs handover to client may be contract-mandatory, but PED is compulsory by legislation.  NoBo will accept things, not the PED.
Helpful Member!  ijzer (Materials)
31 Jan 12 5:35
please note that if the material is to be used in PED cat. III or IV, the certificate shall be  10204-3.2 If the supplier has a quality system specificly for the fabrication/supply of the applicable material that is approved by a European competent body it may be a 10204-3.1 certificate.
ulyssess (Materials)
1 Feb 12 14:11
If the material certificate refers only to an ASTM specification you probably need a PMA, see PED Annex I Par. 4.2 (b) and guideline 9/13
http://ec.europa.eu/enterprise/sectors/pressure-and-gas/files/ped/ped-guidelines_en.pdf
ASTM material is not covered by a harmonized standard.
Close Box
Join Eng-Tips® Today!
Join Us             Close
