ASME Sec IX QW 452.3
If I am putting a 2" nozzle into a pressure vessel (10'ID), does the welder need to be qualified to weld down to 2"? In other words is QW 452.3 applicable? I have had conflicting answers and cannot find the answer anywhere in the code. The vessel is built to Sec VIII. If it is applicable it means that a welder would have to be tested on pipe, without backing, in order to put a nozzle in a vessel which has backing (GTSM).
Any references to clauses would be greatly appreciated. With conflicting answers I can't be sure without a clause to reference.
Thanks!
Thanks!
RE: ASME Sec IX QW 452.3
Your welder will not need to qualify open-root if he will only be welding on backed, or back-gouged & double-welded items.
But if he has the skill, it is better to test using a small-bore open-root coupon. This gives small-bore + big-bore, and open-root + backed/double-welded qualifications. Much more cost effective, and makes scheduling which welder will be welding which joint or nozz much easier; they are qualified on everything.
Does the design call for CJP weld 2" nps? If so, then yes your welder has to be qualified by testing on a 1" OD pipe to 2-7/8" OD pipe thus qualifying the welder to weld pipe from 1" OD to unlimited OD pipe.
Refer to Sec IX QW-452-3 Groove-Weld Diameter Limits.
If your welder is already qualified to some or any size of pipe, he can weld the 2" pipe to the 10' ID pv if the weld called out is a fillet weld with a backweld fillet.
Set-On, with a fitup gap and root = groove weld w/diameter limits for the welder
Set-Thru, fillets inside & out, shell not beveled = fillet, no diameter limit
Set-In, shell beveled full thickness, welded from the outside, or both sides = groove weld w/diameter limits.
You said,
My opinion is, diamter limit does not apply in this case.
Nasir
Welding Engineer
DESCON ENGINEERING LIMITED
PAKISTAN
You are correct
Nasir
Welding Engineer
PAKISTAN
Basically the interpretation simply asks if a welder must be qualified on small diameter pipe for a saddle in type, [UW16.1(c)]for a hole diameter of < 2.875" Answer - No. Same question for saddle on [UW16.1(a)] - answer -yes.
Interpretation: IX-80-08
Subject: Section IX, Welder Performance Qualification
Date Issued: February 27, 1980
File Number: BC-79-341
Question (1): Is a welder required to take a "small diameter" pipe test to weld a "saddle in" [full penetration through shell as in Fig. UW-16.1, sketch (c) of Section VIII Division 1] when the diameter of the hole in the head or shell is less than 2-7/8 in. O.D.?
Reply (1): No, when the weld preparation is made in the head or the shell.
Question (2): Is a welder required to take a "small diameter" pipe test to weld a "saddle on" (full penetration through the nozzle as in Fig. UW-16.1, sketch (a) of Section VIII - Division 1) when the diameter of the nozzle is less than 2-7/8 in. O.D. and the weld prep is made on the nozzle?
Reply (2): Yes.
Question (3): What thickness of plate (test coupon) would a welder have to make his performance qualification test welds on to qualify for production welding of two 1 in. plates to be attached perpendicularly to each other by two partial penetration welds of 3/8 in. each?
Reply (3): The performance qualification test coupon would have to be a minimum of 3/16 in. thick
Nasir
Welding Engineer
PAKISTAN
