HIC/SIHIC service
HIC/SIHIC service
Dear All,
We are assigned to do some repair work for drum,which comes under the service of SOHIC,and as per spec (DEP) If SOHIC testing is specified, it shall be in accordance with NACE TM0103.
But all the plate supplliers decloine for this testing and SOHIC.
since the NACE has withdrawn the TM0103. Please suggest any alternate solution or we have to offer SSC testing instead SOHIC.
RE: HIC/SIHIC service
Maybe suggest qualifying the plate using a standard HIC test to Prudential PS-50 criteria?
The problem would be in sourcing plate that is already qualified to that (or even PS-10) level. Another risk that you also get into is that you can often take "HIC-plate", subject it to a test, and have it fail the test anyway.
If it's a DEP, and the client is someone like (presumably) Shell, you will find that they have some knowledgeable folks on their side that can offer guidance.
SNORGY.
Steve Jones
http://www.linkedin.com/pub/8/83b/b04
Thanks a lot for your guidance.
