Polyurethane Foam (PUF) maxiumum design temperature
Which is the common accepted maximum design temperature for PUF insulation material to be used in a Pipe in Pipe sealine? Is it possible to use up to 110 °C or even more? Thanks
RE: Polyurethane Foam (PUF) maxiumum design temperature
So I should say it´s acceptable.
Assuming that you are selecting the foam on the basis of pipeline maximum operating temperature, a typical maximum quoted for wet service moulded PU is 115 deg C (ref SPE 131618 ExxonMobil). Therefore, it suggests that a dry service maximum for PU foam could be higher. However, any rated temperature should be demonstrated by appropriate qualification testing.
Steve Jones
http://www.linkedin.com/pub/8/83b/b04
