Smart questions
Smart answers
Smart people
Member Login
Join Eng-Tips now!
Join Eng-Tips
LINK TO THIS FORUM!
Just copy and paste the
code below into your site.
Partner With Us!
Partner Button
(Download This Button Today!)
Feedback
"...It's extraordinarily refreshing to see truly expert advice without having to wade through hipper than thou attitude..."
Geography
abramb (Mechanical)
18 Jan 12 3:21
Good morning to all,
I need to perform hardness check on some item using a portable Hardness tester.
The test shall be in accordance to an International Standard, ASTM would be the best option.
I found two possible methods:
- impedance
- resistivity
Hardenss measure by ultrasonic contact impedance method is standardized by ASTM A1038.
Hardness measure by resistivity is standardized by DIN 50157, but is didn't find ASTM Standard/Code for it.
Does anyone know if there is an ASTM Standard for hardness measures by resistivity method?
Thank you, kind regards.
Attilio Brambilla
Material Engineer
http://it.linkedin.com/pub/attilio-brambilla/25/465/544
mrfailure (Materials)
23 Jan 12 17:11
Forgive my ignorance: I am not sure what you mean by resistivity.  You might want to check out ASTM A956 - Leeb/Equotip hardness which is measured using a dynamic rebound method.
Aaron Tanzer
www.lehightesting.com
abramb (Mechanical)
24 Jan 12 2:51
mrfailure: sorry, probably I didn't translate correctly the term from italian language.
What I mean is the measure of the electric resistance, to get the hardness value of the material.
This method is used for example by the portable hardness tester Ernst Handy Esatest
Attilio Brambilla
Material Engineer
TVP (Materials)
24 Jan 12 9:48
abramb,
There is no ASTM standard for hardness measurement according to electrical resistance (Ernst Handy Esatest).
abramb (Mechanical)
24 Jan 12 11:26
TVP,
Ok, thank you.
Attilio Brambilla
Material Engineer
Close Box
Join Eng-Tips® Today!
Join Us             Close
