Chemical reaction water ammonia
3
If I vent ammonia at it´s gaseous state inside a water tank , what reactions, or elements  becomes from it.??
I´m a Refrigeration mechanic , and since the start of the amonnia refrigetarion is working  , every body do it with no problem.
But now I need to tell my customer what will be happen by this method.
Thanks in advance
RE: Chemical reaction water ammonia
Are you venting into the water or into the vapor space?
Into the water
You basically create a aqueoua ammonia solution that get stronger until the water is saturated. Any impurities in the water could be converted to something else, most likey a salt.
Be careful bubbling ammonia through water. Under some conditions it is possible for water to get sucked-up the tube and contaminate your system.
the product is ammonia hydroxide.  NH3 + H2O = NH4OH
if it is slow and the heat can be given up to the ambient atmosphere, you will reach equilibrium at about 30% weight.
the hardness impurities (e.g., calcium carbonates) in the water will precipate out due to the elevated pH.
and if you open the vent into a barrel and forget and then dump water into the barrel, it will likely collapse because the water will absorb the ammonia vapor quickly.
