Profile callout
Profile callout
We have a callout on a customers drawing as follows;
Profile of .0005 to A.....There is a non basic dimension from A of .300
I see this as Parallelism to A, since the .300 is not basic. Am I correct with this definition.
RE: Profile callout
What is Engineering anyway: FAQ1088-1484: In layman terms, what is "engineering"?
RE: Profile callout
Frank
RE: Profile callout
RE: Profile callout
When I see a feature with multiple tolerances, I assume AND, not OR. In this case, it must be within ±0.010", and and profile must be inside an envelope .0005". The plus/minus tolerance is moot.
If the customer wanted parallel, they would have specified parallel.
RE: Profile callout
Though the callout seems at least suspect and most of folks would probably say is illegal or should be avoided, it is absolutely allowed per Y14.5. See fig. 6-18 in 1994 edition or fig. 8-27 in 2009 edition for similar profile of a line application.
And yes, you are correct - this callout controls parallelism of surface relative to A, plus the surface flatness.
P.S.: J-P are you there? I guess it is your hobby-horse.
RE: Profile callout
RE: Profile callout
Small addition to my previous post. The profile callout you asked for controls 4 surfaces parallelism to A, their coplanarity, plus their flatness.
RE: Profile callout
Frank
RE: Profile callout
RE: Profile callout
I really think this drawing is okay but I seem to be in the minority here.
Powerhound, GDTP T-0419
Engineering Technician
Inventor 2010
Mastercam X5
Smartcam 11.1
SSG, U.S. Army
Taji, Iraq OIF II
RE: Profile callout
John-Paul Belanger
Geometric Learning Systems
http://www.gdtseminars.com
RE: Profile callout
RE: Profile callout
Jim Sykes, P.Eng, GDTP-S
Profile Services www.profileservices.ca
TecEase, Inc. www.tec-ease.com
RE: Profile callout
Frank
RE: Profile callout
Had expected a significant fight from other business units when I proposed the use of a general surface profile tolerance rather than ISO 2768, but was relieved/shocked when the proposal was recognized as a solution to many of the woes that some were experiencing.
RE: Profile callout
Did they usally use a single value or a progressive scale for the profile general tolerance. With or without datum references? I have been working on the same thing for a long time and proposed in that my book I spoke of earlier.
Frank
RE: Profile callout
I know that we have been around this bush many, many times but I would love to see how the DRF would apply correctly to all surfaces using the default profile of a surface application.
Could it be possible that the datum reference frame from the bottom of the part (datum A) would reflect the top relative to A|B|C when in reality it should only be referenced as A? Is that possible?
Dave D.
www.qmsi.ca
RE: Profile callout
Peter Truitt
Minnesota
RE: Profile callout
I really don't see the extra datum references as an issue it is a you are describing a complete framework, similar to what is required to measure parts on a CMM I believe the machine wants a complete reference framework (inspection guys?) set up first. If you end up not using all of them it is no real loss. This is the kind of compromises you get with general tolerancing, the standard itself, for many revisions (82, 94) has recommended a similar note for establishing dimensional controls in the past (section 4.4, NOTE).
Frank
RE: Profile callout
I guess I am not a proponent of this approach since all features are treated equally while in real life, some features are vital to the part's function and mating relationship while others are irrelevant to its function. Jim and I have had discussions on this subject in the past and we, respectfully, stand diametrically opposed on this concept.
This approach also contravenes sections of the 2009 edition such as - 4.15 Functional Datum Features - "Only the required datum feature should be referenced in the feature control frame when specifying geometrical tolerances."
After many discussions here, I ended up developing a bit of a web page on this controversial subject.
Dave D.
www.qmsi.ca
RE: Profile callout
Thanks, I would love to look at it. I believe I have seen some of those conversations and thank you also for pointing out 4.15. I would tend to agree that they seem to be at odds. Like I said earlier general tolerancing does tend to blend all features together as if they are all equal, this is just as true for any titleblock tolerancing scheme so it is not new.
Frank
RE: Profile callout
Dave D.
www.qmsi.ca
RE: Profile callout
Peter Truitt
Minnesota
RE: Profile callout
Each part would have its own general tolerance value, and drf. This appeases the Y14.5 requirement that all features be controlled. Beyond that, you override with local controls. I.e. appropriate controls on your datum features, tighter or looser controls where needed/warranted on specific features. Some of us who were more experienced would base our values on process knowledge and industry standard such as 2768, while others would pull a thumb-suck from 2768 without understanding the implications. There were various philosophies about selecting which tolerance to put in the general tol frame too; ISO requires the loosest shop capability (or is it the tightest; I keep forgetting) while some designers emphasize the tightest with all looser tolerances being directly applied. To me, it made sense to reduce detailing time by selecting the most common acceptable tolerance. I found that most people then rationalized that they typically were too restrictive with their tolerances on most features anyway, and ended up accepting the general tol as adequate for even more features.
Yup, Dave, we agree to disagree.
Now, on 4-15, these are my thoughts; there is no HARM in adding the datum references even if they are not required for functionality PROVIDING THAT it does induce an additional setup for inspection. I say this because if the DRF is not filled in, then you would need to break down the inspection setup to eliminate over-constraint; I pretty much guarantee that a CMM operator doesn't break down the datums for a new feature. Taking a blend radius as an example, there's no value in the DRF - agreed - but are you going to break down the setup to verify it?
Overall, nothing should be a carte-blanche for design or inspection, but some conveniences can save both parties significant time and effort ... and a general surface profile has proven to be one of them for many situations.
RE: Profile callout
It may.
RE: Profile callout
Thanks.
