Where is web page opened via VBA macro stored on C: drive?
I am running this code in Excel VBA:
which opens this page as a read-only file. Where is this file stored on my C: drive? I have looked in C:\Users\Default\AppData\Local\Microsoft\Windows\Temporary Internet Files and it is empty. I have also looked in Libraries\Documents, where the MS Excel file is saved, and I did not find it there either. I also have looked in C:\Program Files (x86)\Microsoft Office\Office12 and I still did not find anything.
Where is this file stored?
CODE
Sub marco1()
Application.Workbooks.Open "http://www.eng-tips.com"
End Sub
End Sub
RE: Where is web page opened via VBA macro stored on C: drive?
That's not surprising, since Workbooks.Open is supposed to open a WORKBOOK. It's not saved anywhere until you do a SaveAs.
TTFN
My concern is in this section of code:
CODE
On Error GoTo internet_access_required:
Application.Workbooks.Open (Web_Page)
On Error GoTo not_authorized:
Cells.Find(What:=authorization_key_word, After:=ActiveCell, LookIn:=xlFormulas, LookAt _
:=xlPart, SearchOrder:=xlByRows, SearchDirection:=xlNext, MatchCase:= _
True, SearchFormat:=False).Activate
'close Web_Page
Application.ActiveWorkbook.Close savechanges:=False
Application.DisplayAlerts = True
Exit Sub
Sometimes the page opens slowly. Is it possible for the user to find that instance of the web page on the C: drive? Is it possible that the user interrupts the macro prior to running:
CODE
I know that Excel has an auto-save feature. Where is the location of the file that is automatically saved?
This is the complete code. Web_Page, authorization_key_word, WBook_Password and Sheet_Password are strings defined elsewhere in VBA. The webpage is a blog that only I can access.
CODE
Application.DisplayAlerts = False
'OPEN INTERNET WINDOW AND REVIEW AUTHORIZATION
'close Web_Page
Exit Sub
'goto NOT AUTHORIZED
not_authorized:
'delete all sheets
ActiveWorkbook.Unprotect Password:=WBook_Password
Sheets.Add Before:=Sheets(1)
While Sheets.Count > 1
Sheets(Sheets.Count).Visible = True
Sheets(Sheets.Count).Unprotect Password:=Sheet_Password
Sheets(Sheets.Count).Select
ActiveWindow.SelectedSheets.Delete
Wend
Sheets(1).Protect Password:=Sheet_Password
ActiveWorkbook.Protect Password:=WBook_Password
'save and close this workbook
Application.ActiveWorkbook.Save
MsgBox prompt:="Use not authorized." _
& " This application will now close.", _
Buttons:=vbCritical, _
Title:=verification_title
Exit Sub
'goto Internet access required to run this program
MsgBox prompt:="Internet access is required to run this program." _
'close this workbook
Exit Sub
End Sub
The Autosave goes to whatever folder is the default, unless current directory is changed by the user during the time Excel is opened.
TTFN
