Using GM and Chrysler load on same work station
We are using NX7.5 for both GM and Chrysler programs. Can both seperate loads be used on the same work station without any issues? We need to generate drawing for both customers using their specific applications on the drawing side.
RE: Using GM and Chrysler load on same work station
There are a lot of GM specific customizations loaded in the customer settings.
Ben Loosli
As long as you set your environment variables to point the correct locations and use separate customer defaults, you should be able to run multiple environments from the same install. You just don't want to overwrite what GM or Chysler have set up - try putting that portion in 2 different directories and see how that works.
You certainly aren't going to ruin NX by attempting to load both on one workstation - you'll just have to test it out, I'd imagine.
Tim Flater
NX Designer
