minimum wall thickness ASME B16.34
I need help with ASME B16.34. The minimum wall thickness dimension is meant to X or Y?
thank you
RE: minimum wall thickness ASME B16.34
For 16.34, Y must meet the minimum wall, and should easily because it is a gasket sealing face.  Gasket face width is several times greater than min. required wall.
Because this is a wafer style body, X is no.  You should not dead-end a pipeline with this valve without a blind flange covering the X.
The wall thickness formula is given in appendix F. Which is a form based on the hoop stress and may not apply to the flat section of a wafer type. Other criteria as sealing requirement will govern.
Also see link, http://www.eng-tips.com/viewthread.cfm?qid=309703
