Smart questions
Smart answers
Smart people
Member Login
Join Eng-Tips now!
Join Eng-Tips
LINK TO THIS FORUM!
Just copy and paste the
code below into your site.
Partner With Us!
Partner Button
(Download This Button Today!)
Feedback
"...I just want to say how much I value your site. I hope the good work keeps up there. It's really helped me..."
Geography
matle (Structural)
17 Jan 12 6:43
We have some non structural marine hardwood going in on a project and a piece of it is cracked. Aesthetically we may be able to live with it as it stands but the concern is it developing over time.
Does anyone:
a) have experience of cracked hardwood in a marine environment - will these cracks expand significantly over time?
b) know of any guidance available on quantifying how much worse we can expect this crack to get?
c) have experience of remedial measures? The two I can think of are coach screws or infill with a resin but I am not clear on how effective either of these options are.
IRstuff (Aerospace)
17 Jan 12 10:29
How big, how deep?  Is it purely decorative, i.e., hanging on a wall, or is it subject to wear/stress?
TTFN
berkshire (Aeronautics)
17 Jan 12 14:33
What is the function and species of this piece.
Can the crack be glued?
 I have Mahogony gunwhales on boats with cracks that have been there 50 years.
 Send more information.
B.E.
The good engineer does not need to memorize every formula; he just needs to know where he can find them when he needs them.  Old professor
matle (Structural)
17 Jan 12 14:56
It's a timber rubbing strip along structural steelwork appx 100mm deep, 300mm tall and 2000m long.
The timber is ekki so good quality. The crack is at one if the corners & if it got worse you could expect a section 150mm square and appx half the depth (150mm) falling away.
IRstuff (Aerospace)
17 Jan 12 15:41
2000m long??
As defined, a "rubbing strip" will encounter random and harsh loads, so it seems to me that such a device will break off under use.
TTFN
matle (Structural)
17 Jan 12 16:02
It's in sections bolted and supported continuosly along its length.
17 Jan 12 17:37
Just change it when it breaks.
B.E.
chicopee (Mechanical)
18 Jan 12 21:00
A friend of mine who owns a boat used an epoxy compound to repair dry rot on his wood deck.  Go to a marina and ask for help as there is material for boat repairs involving wood.
Helpful Member!  berkshire (Aeronautics)
19 Jan 12 3:35
Matle
If you really need to fix it, Take some wedges and pry the joint apart a little. inject some one part moisture cured urethane glue ( Gorilla glue or Baltek ) into the joint and clamp it.
 The glue will expand filling any gaps, and will give you good service. The wood will most likely break before the glue fails.
 It will be best to do this on the dock before you put this timber into service
B.E.
matle (Structural)
20 Jan 12 9:01
berkshire - thank you for the response with the urethane glue, it was exactly the sort of guidance I was looking for.
Unfortunately inspecting the piece on site I concluded the wood was in worse condition than originally indicated and had to reject it on quality grounds. It is a bit of a pain but the supplier has assured us they will get a replacement on site in time that it won't affect the programme.
20 Jan 12 15:07
matle
I looked up the species you were using. It is called African oak or Ironwood in the USA where I am residing.
 It does have a tendency to develop shakes when drying, so I would recommend that you look closely at all of your timbers before you put them into service.
B.E.
Close Box
Join Eng-Tips® Today!
Join Us             Close
