Is This Correct? Attached is simulation.
Attached is a jackstand assembly, i tried my best to model the situation as close to real life as possible. I need to make sure the pin is safe for use - I just want to know if the actual boundary conditions, restraints and loads are correct..
I can alter the pin diameter at a later date.
Thankyou!
