Unkown unit of piston and rod area
Hi again,
Can anyone please shed some light on a unit of area I've not seen before? I'm using a software called FluidSim to simulate various pneumatic circuits. When I open the dialogue box to adjust a double acting cylinder's parameters, I see the units of piston and ring area as "qcm" (see attachment). In the pull down tab, you can also select "qmm" and "qin".
What's funny is that when I read the help file (see attachment), it says nothing about this unit, and in fact tells me that the adjustable parameters is actually the diameter.
Googling, I found something about an ancient Roman unit of area called the quinaria, but not sure exactly how this relates.
Any help is appreciated.
Vitorio
Vitorio
RE: Unkown unit of piston and rod area
Ted
Thanks again.
