Continue dimension
Continue dimension
Been using this for years however only the other day I noticed that Ive been clicking on an extension line (short dimension only of 140mm)to start the continue dimension but in fact the dimension line starts from the far dimension extension. Been turning off osnap but still happens.
Anyone come across this annoying little problem which could lead to wrong dimensioning in final drawings?
RE: Continue dimension
When Im promted to select the extension line I click on the one I want to continue from. How can this be done from clicking on the command ?
