Threaded hole line color in modeling
Can (how) you change the dashed line color representing the i.d. of a threaded hole in modeling. Now it is the same as the bodly color which is very difficult to see. Much like you can change the color in drafting. ??
Chris
NX8.0
Chris
NX8.0
RE: Threaded hole line color in modeling
I see that it is possible in "Drafting" to do it, but not in "Modeling">
I hope, for your sake, I am wrong.
You will probably find that your arcs & solids are using the same value of default so they end up the same colour.
Change either one to specific colour using Preferences -> Object, then change the Type to whatever you want to change and specify a colour. This will only apply for the current part but you can change your template parts to make it permanent.
Anthony Galante
Technical Resource Coordinator
NX4.0.4MP10, NX5.0.0->5.0.6, NX6.0.0->NX6.0.5, NX7.0.0->NX7.0.1 & NX7.5.0.32-> NX7.5.4.4, NX8.0.0.25
John R. Baker, P.E.
Product 'Evangelist'
Product Engineering Software
Siemens PLM Software Inc.
Industry Sector
Cypress, CA
http://www.siemens.com/plm
UG/NX Museum: http://www.plmworld.org/p/cm/ld/fid=209
Chris
