Automatic feature classification into geometrical set
I would like to know if somebody has a method/script/macro to automate the classification of features into respective geometrical sets (CATIA V5).
Example : Creating a "Line" would put it under the geometrical set "Line" even if this particular geometrical set is not "defined in work object".
I group all reference elements independently from my surfaces so I can hide all the wire-frame geometry at once.
Alternately, a macro for showing/hiding all wire-frame geometry would work, but I would prefer to have the same features grouped together for the tree's sake.
Thank you very much
RE: Automatic feature classification into geometrical set
If I understood you well, that means after creating a feature (for example a line) you want to run a macro to pick-up the feature (line in this case) and put it in a specific GS (selected by you or predefined), isn't it ?
This can be done without problems.
Fernando
Precisely, except that I would rather have something that does it in real time if possible, instead of a macro that has to be launched.
Thank you for your reply Fernando, much appreciated
In real time I believe is not so easy because there are too many ways to create a feature...let me think...
Fernando
I just realize that it will be much easier to do what you want if you search a specific feature at the end of the work (let say lines) and just CHANGE one type of feature (lines) in a specific Geometrical Set - Change Geometrical Set
Fernando
This is just a simple CATScript
Language="VBSCRIPT"
Sub CATMain()
Dim partDocument1 As Document
Set partDocument1 = CATIA.ActiveDocument
Dim selection1 As Selection
Set selection1 = partDocument1.Selection
selection1.Search "CATPrtSearch.Line,all"
Dim part1 As Part
Set part1 = partDocument1.Part
CATIA.StartCommand "Change geometrical Set"
part1.Update
End Sub
Fernando
I get this error message...
Source : Microsoft VBScript compilation error
Description : Expected end of statement
Statemenet : Dim partDocument1 As Document
I'm a newbie with scripts...
Thanks Fernando
Wow, works perfectly! I owe you a beer ;)
I've created some for planes, points, sketches also...
Where can I find the feature name's list to correctly designate the  other one? (Spline or 3D curve perhaps)
Another quick question ; let's say I create an extrusion and I define the direction by creating a line within the extrusion direction's contextual menu. The line will be under the extrusion's node in the tree, hidden. That's fine by me... Is there a possibility to skip the features that are defined this way?
Again, thank you very much for your time
Best,
Mat
First question: push CTRL+F and look in Advanced Search Tab for Part Design Workbench.
Second question: you have the possibility to exclude from a selection different things, you just need to find the criteria...maybe an example uploaded here it will be much helpful to find a solution.
The CATScript is done by simply recording and just add a StartCommand line at the end...is really nothing fancy...and for sure can be improved (in catvba, with graphic interface, buttons, less clicks, a.s.o.), you need just a little time - unfortunately I don't have now so much..
Fernando
