Problem with Steel design with a user-defined section
I wonder if anyone can see any mistake in the way I have defined the Member Property of a Tee section in the attached file.
It is a short trial analysis model file. The analysis part runs fine. But the design and stress check part does not run saying there is a mistake in the member property input.
Exactly the same file using a standard rolled section also runs fine. Also the way I have defined the tee section has been used in many Staad examples.
I will appreciate your help.
RE: Problem with Steel design with a user-defined section
