Caita V5 Drafting Sample Formats
Does anyone have the old drawing format sample that use to be in catia v5. I believe the file ext was *.dwg. Or does anyone have any samples they can share. I use to take the sample dwg and just create or edit to make new ones. Any help would be great. In a bind.
kevin
kevin
RE: Caita V5 Drafting Sample Formats
Search where you have CATIA installed for c:\Program Files (x86)\Dassault Systemes\B18\intel_a\VBScript\FrameTitleBlock\ - (in my case this is it) , you will find some scripts which will generate some samples... . Extension should be CATDrawing not dwg.
Fernando
Kevin
