Temprature Loads for steel buildings
I am working on a 350ftx185ft building - 175ft to 150 ft high. . Temprature difference (winter and summer months) is 80F. Building is heated but not air condioned. I have following issues to discuss
1- No expansion joint - should we design for temprature load. if yes - loads are so high it appears unreasonable.
2- if we provide expansion joint only at roof purlins (slotted holes) about at 125 ft length should we still need to design for temprature load for both sides of the building.
3- Do we need to provide expansion joint throught out the height of building for every beam attaching to this bay (125 ft location). and do not consider any temprature load.
4. for expansion joint we can not provide double cols. we left out with slotted holes option. any thought.
I need your help and advice in this matter.
I appreciate all feed backs. Thanks
RE: Temprature Loads for steel buildings
Dik
Dik
what kind of movement joint should be provided. we can not provide double cols at this stage.
Dik
Dik
