Stepper Motor RPM
Stepper Motor RPM
What do I need to know to calculate the RPM of a stepper motor? I know the type of motor, number of pulses, voltage - and that's about it. Thanks - Dave
RE: Stepper Motor RPM
Steppers are designed to receive voltage pulses from a controller; think of a rotor with 200 poles. The same analysis rules for AC/DC motors don't apply. Pulses will make the rotor increment 1 rotational step. Generally motors are designed with 1.8 degree of rotation steps (200 steps/rev). Pulse streams are fed to the motor in a acceleration ramp-up / steady velocity / deceleration ramp-down profile. RPM is determined by the controller capability and pulses/revolution resolution, can be 1000's RPM.
Alternatively, modern stepper controllers can be "microstepping" controllers. These divide each default step into fractional steps. This makes the effective resolution 10,000's of pulses/revolution.
To add a corollary to Mike's comment, call the CONTROLLER manufacturer.
TygerDawg
Blue Technik LLC
Virtuoso Robotics Engineering
www.bluetechnik.com
Please also note they don't ever really rotate continuously. When the state of the voltage pattern applied to the coils changes, the stepper moves, usually within a millisecond, and then stops, or if friction or inertia is too large, it moves a little, stalls, and falls back to where it was.
To learn more, Google leenhouts stepper
Mike Halloran
Pembroke Pines, FL, USA
