NX7.5 COPY PASTE?
NX7.5 COPY PASTE?
We have a part that has some equations to define a law curve of wireframe geometry. For this example it is a gear tooth. But if I copy and paste this solid body from one part to another I loose all expressions from the orignal part in the part I am adding to.
For this example I have a shaft and I want to put splines on the shaft. So I have the shaft as a revolve and I want to put some splines onto the shaft from our gear template part. What would be the best way of doing this? Copy and paste does not work very well as we loose all of the expressions after the paste into the shaft if done.
Looking for a more robust way of doing this.
RE: NX7.5 COPY PASTE?
John R. Baker, P.E.
Product 'Evangelist'
Product Engineering Software
Siemens PLM Software Inc.
Industry Sector
Cypress, CA
http://www.siemens.com/plm
UG/NX Museum: http://www.plmworld.org/p/cm/ld/fid=209
thanks for the feedback.
