Moment of inertia
Moment of inertia
Hello all,
How do i add Area moment of inertia in the query through measured bodies? It only gives me Mass moment of inertia.
RE: Moment of inertia
Analysis -> Section Inertia...
...or...
Analysis -> Advanced Mass Properties -> Area using Curves...
John R. Baker, P.E.
Product 'Evangelist'
Product Engineering Software
Siemens PLM Software Inc.
Industry Sector
Cypress, CA
http://www.siemens.com/plm
UG/NX Museum: http://www.plmworld.org/p/cm/ld/fid=209
In either case, what you're supposed to do is use either (but NOT both at once) a profile of curves, such as a section though the model, or a face which represents the profile of the model, which can often be the end face of say an extruded model with a constant cross-section.
With the older 'Area using Curves' you can only get a single result for a single profile, but with the 'Section Inertia' function you can define a set of cross-sections if you need to see how the area properties of a model varies as you move along some axis or curve.
John R. Baker, P.E.
Industry Sector
Cypress, CA
John R. Baker, P.E.
Industry Sector
Cypress, CA
