Cathodic protection in an acidic environment
We have a situation where we are using a rotating screw to move an abrasive slurry through our process. Because of the abrasiveness, the material of the screw and housing is 440C stainless steel, heat treated to a Rockwell C of around 50. Now our process people have begun to add lactic acid to the process, causing pretty severe corrosion of the 440C parts. Will a sacrificial anode help in a situation like this? The temperature is around 300° F. Would hydrogen embrittlement be a concern?
RE: Cathodic protection in an acidic environment
Corrosionman
