NX 8 Cam-Cut regions in lathe
I get two different cut regions (Lathe-Facing) when I use two different computers using the same file. I'm using Axial trim plan
to machine the face. When I select the area I get a Alert "Part geometry not located within cut region containment". On the other computer I do not get this alert.
Both computers have the same graphic cards?
What could be the cause?
RE: NX 8 Cam-Cut regions in lathe
BTW my machine spc.
Win 7 Pro 64-bit SP1
Intel Core i7
8Gb Ram
PNY Quadro 4000 (also installed the latest driver from Nvidia, no change)
NX 8.0.0.25
Please contact GTAC with this issue. They can check what's different between your sessions, and create a PR if necesary.
Mark Rief
Product Manager
Siemens PLM
