Save Body from all cut-list folders API
I want to save all the bodies from a part even if there are body-folders created when you update the cutlist in a welded structure.
In the example given by the help it works if you exclude the cutlist and all the body-folders are removed.
Is there anyway? I try to merge the values of folder.getbodies in each folder to merge then in a single array but i couldn't find a way.
