How to constrain nodes in positive axis only? (I-deas Master series)
3
Hi guys,
I am trying to constrain(arrest) the movement of a bracket surface in positive direction only(say Y-axis) and let it to be free in -Y axis.and it has to be free in all another axes.
I need to do so , beause the surface i need to arrest , as said above is in contact with other part.Just like anti rotation flange.
Is there  any option in I-deas software for this..
Please help me..
RE: How to constrain nodes in positive axis only? (I-deas Master series)
thanks greg for ur reply..
But i am doing linear analyis only..
Ok.. how anti rotation flange can be simulated in FEA.. i mean what kind of restrains i have to give..
Am confused in this linear , non linear model concept.. i thought that linear is regarding to material like steel and non linear to steel. but now i feel that my understanding is wrong..
Please anyone clarify this linear,  non linear concept
You can have "linear contacts" in a model (ie tied contact) but in reality these are not a true contact condition and are usually achieved by linear constraint equations or derivations thereof.
Non-linearities in a model can be introduced by materials (eg plasticity), geometry (ie non-linear geometry such as displacement-dependent stiffness or large strain/displacement) or through other changes in model stiffness (ie contact, such as stick-slip). As mentioned, you will likely need to consider some form of non-linearity to achieve what you need - the good old-fashioned gap element might suit your needs here.
See FAQ569-1083: Asking questions the smart way on Eng-Tips fora for details on how to make best use of Eng-Tips.com
thanks drej, crisb..
I found one element type called "constrain elements" in I-deas SDRC.
Will it be possible to solve that contact issue.
If not please consider any method to simulate this..
I am attaching the illustration i need to constrain.
hi..  please anyone reply for my above post...
i need ur help..
