Putting a 3'' Hole through 1.5'' Thick Iron in a Punch Press
Does anyone have any creative ideas for putting a 3'' round or square hole through a 1.5'' thick cast iron in a punch press?  The hole doesn't need to be clean or any specific size, it just needs to be large enough for a stamping to drop through it.  My fallback was to chain drill it, but that is time consuming and there is not enough clearance for the drill up top, so I would have to drill it from underneath.  I was thinking I would start with a pattern to start the holes and then just chain drill it with 1/4'' holes.
RE: Putting a 3'' Hole through 1.5'' Thick Iron in a Punch Press
A square hole is harder to drill <G>.
Can you use a 3" bi-metal hole saw and maybe drill from each side?  They are really fast for cutting and I've used them for 1" plate.
Dik
Cast iron is not amenable to punching.  It will shatter.  Drilling will likely be your only recourse.
One drilled hole and a variable speed saber saw and some patience might do it.
Mike Halloran
Pembroke Pines, FL, USA
I had to re-read that two or three times.  At first, it sounded like you wanted to punch a 3" hole through 1.5" cast iron.  But I gather that the hole is going to be made in a punch press frame?
Beware, you're also weakening the frame when you do that.
You can get core drills that will cut a plug, but I don't know if they're practical for your situation.  Seems like the ones I've seen were shallower.
JStephen....after I read your post I went back and re-read the original...your interpretation makes more sense.
A diamond core drill will do the three-inch diameter hole.  Use a concrete coring bit. You might dull the bit enough that it will be useless thereafter, so get ready for the cost of a new 3" diamond bit...about $250 US.
Correction... a bi-metal blade will not do cast... a diamond core drill is likely the only way to go. Cast is too hard for a bi-metal.
Dik
I have cut many many cast iron pipes with bi-metal blades over the years.
What you are doing seems like it would be a real pain with a blade.
Maybe drill four holes and connect them with a blade./
You can't punch it - it will shatter as noted.  Drill, saw or flame cut??
Toad... I've done 3" holes in 1" steel plate with a circle saw... much easier than cuting with a torch and smoothing... it cuts surprisingly quickly.  Even smaller holes for bolts, etc. are faster to cut with a circle cutter than using a regular large diametre drill.
Dik
