Bracket Bending vs. Welding WRT to Cost
Hi all, I have a question concerning costs for different manufacturing processes. I'm a rather fresh ME, so please bear with me. I am concerned with the cost of manufacturing the bracket depicted in the attached image. I am looking for the lowest cost option to manufacture the bracket from 3/16" thick, 4" wide, low carbon steel.
In general, which would be lower cost: bending a single piece of steel sheet, or welding 3 pieces to form the bracket. Is there a lower cost option than those aforementioned?
Thanks for your help, and please let me know if I left out any pertinent info!
RE: Bracket Bending vs. Welding WRT to Cost
It all depends on the tooling your fabricator has (one can do it another cannot because they don't have the tooling).. But I suspect this shouldn't be an issue. In fact I just looked in my Wilson tooling catalog and this is not an issue with their taller gooseneck tooling.
It's better to not specify an exact bend radius because it's dependent on what tooling is available, but to instead specify a maximum radius that you can tolerate, and let the fabricator work out the details.
Mike Halloran
Pembroke Pines, FL, USA
How many do I need to make?
What are the tolerances of the part?
What equipment do I have? Do I have a pressbrake? Do I have a welder?
How much do I want to invest in tooling and equipment?
