'Normal' oil consumption
If we compare two equal engines that use the same type of oil, is it possible that they use different amount of oil and still have the same fuel consumption and power generation? In other words, is engine that use less oil better engine?
Car manufacturers say that up to 1l per 600-1000 miles are still normal consumption.It is possible that one new car uses 0.1l in 7500 miles and another new (same brand, same model) uses 1.5l in 7500 miles. Is it possible that these engines have the same power figures?
RE: 'Normal' oil consumption
Some engines however will do that and it can easily vary from engine to engine. Kind of depends who was tightening bolts, setting rings and gaskets that day!!!
One thing I've noticed: 40+ years ago, 1.0 l of oil lost per 600-1000 miles was also called 'normal', and was in fact representative of most of the new engine production at the time.
Now, <l.0 l in 7500 miles seems to be more typical.
I'd guess it's because of better seals, better rings, automated assembly, EGR, and semi-closed crankcases.
Mike Halloran
Pembroke Pines, FL, USA
h
If a 4 stroke engine is allowing much oil at all into the combustion chamber the effective octane is reduced, which >could< require pulling back the ignition timing to reduce detonation, and >could< result in less power, too.
I'm not sure I'd expect a strict connection between oil consumption as a measure of 4 stroke engine assembly quality, internal condition or power output. for instance, a crankcase ventilation system overdue for maintenance could drive the oil consumption up, even though mechanically the engine could be in fine shape.
Mike---Yeah, my '49 Mercury was only 8 years old and used about a qt. a week and the dealer said that it was "normal"...
Today most Ford products have such marvels as "sealed automatic transmissions" and it is not at all uncommon for a new engine to have 'zero'(?) oil consumption at extended service intervals. I chalk it up to better mfgr techniques, metallurgy, lubrication...that and the 'march of time'...seems like yesterday, doesn't it? My old Dodge/Cummins has over 300k miles and it still does not "use oil"...less than a half qt. in 3000 miles!
Rod
Slightly longer answer. RIR (Rod Is Right)
Bore finish, ring end gap or side clearance, pistom oil drain back holes and valve stem seals can all have a large impact on oil consumption from burning without necessarily having any real adverse impact on power.
Of course oil leaks have no influence on power whatsoever but it makes an obvious mess.
Manner of use also has a strong influence on oil consumption.
Pat
See FAQ731-376: Eng-Tips.com Forum Policies for tips on use of eng-tips by professional engineers &
http://eng-tips.com/market.cfm
for site rules
However, somewhat in favor of your hypothesis, I did have one fella working for me that claims he drove a new Ford Bronco V8 100k miles without changing or adding oil......Okay, I hear ya. But...this fella was from Jamaica and, not meaning any disrespect to most Jamaicans.....One day I gave him my new gloves, his had big holes in them. Thanking me with big smile...made me feel good. Next morning he had put duct tape on all the fingers...said it made them last longer. I dunno! Maybe he actually did drive a Ford V8 that long without adding or changing oil.
Rod
If that happens and the oil is not changed before the next occasion the car sees a reasonable distance on a highway, all the water boils off and the level drops noticeably in a very short time and leads people to incorrectly conclude their engine only uses oil at high speed.
Pat
for site rules
But you say it's not necessary the case, can you give more information about it. Is it possible that oil consumption increase rapidly with even slight wear and very small power loss due to wear?
I guess it would be the long sweeping corners where your not really pulling but feathering the throttle.
I don't know anything but the people that do.
Poor valve stem seals have no impact on blow by.
Wider piston to bore might allow a little more blow by but might also reduce friction.
Etc etc etc. It really is much more complex than you seem to realise.
Pat
for site rules
Problem, in this case, being that even when new they use one or two quarts of oil between oil changes, and the people who bought Accords want a hands-off transport appliance without any of that bothersome looking-after. (My guess is that Honda went a little too light-tension on their piston rings, in order to squeeze out that last drop of fuel economy)
At the opposite end of the spectrum are rotaries, which can and will go overfull with use, if the oil injector unit is disabled. My personal car adds roughly one quart per 600mi.
