Identifying component by component ID?
I am wondering how to identify components in an assembly via the reported component ID in the information window at the top of the screen. Specifically, I have an assembly that will not regenerate fully with the following message:
Warning: Cannot update placement of component (M9165).
How do I figure out which part is component (M9165)? There is probably a simple explanation for this but I am not clear on how to interpret this.
Thanks in advance for your help!
RE: Identifying component by component ID?
  Wouldn't the components be identified through a Master-Model CAD structure?  Each component is a child component that is partof the Master Assembly.
  Perhaps, a CAD naming convention, structure or nomenclature would help too if you have identical part numbers that is part of this "M9165" Assembly.
  At least through a Master-Model CAD structure, you will be able to control individual components & its revisions too.
Does this help?
Show the feature ID in the model tree.
Thanks dgallup. That is what I was looking for.
