how to Create Profile & cross Section in Land development??
I've measure Rl at regular interval of chainage.
Chainage           RL
0+000
Now i want to create profile of ground along CL. How
 can i do it? without need of creating surface.
Also i have measure the vertical offsets at regular horizontal distance on both left & right side of Cl.
How can i plot Cross section??
-3 0 3
-1.2 0 2
RE: how to Create Profile & cross Section in Land development??
I am pretty sure you need to create a surface if you want the software to automatically cut you cross sections.
B+W Engineering and Design
Los Angeles Civil and Structural Engineering
http://bwengr.com
Thank you for response Brandonbw.
But I already managed to do it. :)
How?
EIT
I am curious what you ended up doing too without creating a surface.
http://bwengr.com
Need to have Civil Design installed in Landdesktop.
Create a pline & define it as an alignment
then import X-section measured field data.
Cross-section>Existing ground>Sample from file
{text format for file}
chainage
S .
-left Elevation
0 elevation
+right elevation
E
Profile>Existing ground>Sample from Cross sections
Profile>create profile>full
profile shall be created
Profile>FG centerline tangents>create tangents
Profile>FG vertical alignments>import
now create formation x-section
Cross-section>Draw templete
Cross-section>design control>edit design control.
Select formation templete & cut & fill slopes
Cross-section>total volume output>onscreen or anyother option.
Thats all i know.
