High speed relay
High speed relay
G'day!
I'm needing a relay with a very fast switching speed to control a circuit. Do you know what are the fastest relays that are available in the market?
Cheers,
Work Experience Kid
Cheers,
Work Experience Kid
RE: High speed relay
Bill
"Why not the best?"
Jimmy Carter
An ordinary little reed relay switches in 50 - 100 microseconds. That is fast. But contacts cannot take much load. Solid state switches (IGBTs, MOSFETs) switch in a few hundred nanoseconds and can carry hundreds of amps and thousands of volts. But have some zero crossing distortion. Good for DC, though.
A standard relay switches in milliseconds and a contactor needs ten or twenty ms.
You need to specify your needs better if you want a specific answer.
Gunnar Englund
www.gke.org
