Plastics material library?
Hi all,
Some google-ing has left me hi-and-dry as to a reasonably good plastics material library for ProE/Mechanica Wildfire 4.0.  When I have a model and want to set it's material, I have about 15 choices, and all but 3-4 are metals.  The attachment is a screen capture of my (limited) available materials.
Do I just not have a config pointing at the right directory, or do I need to add materials?
If I need to add materials, can someone suggest a good plastics library?
Thanks in advance.
RE: Plastics material library?
Hi
Try with www.matweb.com. It is FOC. More options if you make registration.
