Modify location of the CATENV File
Is there a way I can change the directory the CAT Env is located?
I have it in a sub directory off of the env but I want to put it back a directory. Is this possible?
RE: Modify location of the CATENV File
"C:\Program Files\Dassault Systemes\B20\win_b64\code\bin\CATSTART.exe" -run "CNEXT.exe" -env CATIA-64.V5R20.B20 -direnv "K:\CatiaApps\Settings\CATEnv" -nowindow
You can change in Windows using - Start - Catia - Tools - Environment Editor V5R??
Modify the Global Environment path under Options --> Set Global Storage Directory.
You can also change the catenv using setcatenv. Search that in the help and it brings up examples under Customizing your Environment on Windows.
Derek
Win XP64
R20/21, 3DVIA Composer 2012, ST R20
Dell T7400 16GB Ram
Quadro FX 4800 - 1.5GB
