NFPA - Sway Brace
NFPA - Sway Brace
Is there anybody can help me whether I should provide sway brace in my design of fire protection system, in case yes. What in NFPA states that I should provide sway brace in my piping. Do I have to consider the siesmic zone map on our location.What if the location based on the seismic map indicates that it is a low hazard seismic zone, should I need this sway brace.My project is located in qatar and its a office type building. please help..
RE: NFPA - Sway Brace
If you need to do seismic protection, look into chapter 9 of NFPA 13 (2010 edition) for the seismic bracing requirements. Don't forget branch line restraint and to check the max loads for lateral bracing of the braced pipe.
Travis Mack
MFP Design, LLC
www.mfpdesign.com
http://www.ameinfo.com/116435.html http:/
