Generator field saturation
If a generator field saturates power output decreases this at the same time increases steam flow to turbine without changing steam pressure profile in turbine. i would like to know in detail , what would be the quantity of power loss and how to calculate it. please give in detail how to calculate power consumption due to field.
RE: Generator field saturation
where
|Is|=(Xms x Ns' x Ef)/[(XLs + Xms) x Rf] is stator current in Amps
Ef rotor field voltage in Volts
Rf rotor field resistance in Ohms
XLs is stator leakage reactance << Xms in Ohms
Xms is stator magnetizing reactance in Ohms
Ns' = 3 x Nr/(sqrt2 x Ms x Ns)
Ms is number of stator phases
Nr number of rotor turns
Ns number of stator turns
the dc field in a syn. gen. does not "saturate", however the ac core saturates and this limits the voltage induced in the armature winding by the field.
Second, changing excitation (magnetization) levels in a synch. generator changes Var generation not Power generation. Only the steam turbine governor can change Power output of the generator.
Now changing Vars loading will change the losses in the generator(stator core loss, armature loss, stray load loss) but these losses are small compared to the power output in any well designed generator.
