Feature Distance Expression.
I have a model that contains a feature I never seen before-"distance expression"(see att file).
I can see the expression under tools/expression, but I can`t change it.
How do I get it and how/when is the function used?
RE: Feature Distance Expression.
Open you expressions menu and go to the bottom of it, the second icon from the left is the "measurement menu".
Something similar is also located under your "analysis" pull down - but in that menu you need to toggle on "associative" for an expression to be created.
John R. Baker, P.E.
Product 'Evangelist'
Product Engineering Software
Siemens PLM Software Inc.
Industry Sector
Cypress, CA
http://www.siemens.com/plm
UG/NX Museum: http://www.plmworld.org/p/cm/ld/fid=209
Tried to upload the file again.
John R. Baker, P.E.
Industry Sector
Cypress, CA
John R. Baker, P.E.
Industry Sector
Cypress, CA
I have attached a part that contains a feature "distance expression".
Back before we had implemented the more general Measuremenet Expressions, where you can capture, either using associative functions on the Analysis menu or the explicit Measurement Expressions created inside the Expression system, things like Distance, Length, Angle, Area, Volume, etc. of various aspects of your models, we had a single simple 'Distance Expression' function as part of the Expression system (and which was replaced by these newer functions). In your example part, this is where that particular 'Distance Expression' feature originally came from, which in this case was created using UG V18.0 on May 16, 2003 by someone with the user ID 'JONASSMA'. Note that this information can be gleened from your part files using...
Information -> Part -> Part History...
...where you can get a complete history of who worked on a particular part file, when they did this work and what versions of the software and OS were they using, and if you cross references this information with what you can learn using...
Information -> Part -> Modifications...
...where you can track when features and expressions were created and edited, you can get a very detailed 'history' of the evolution of your part files.
Note that this 'Distance Expression' feature was created with UG V18.0 using a function then found on the Expression dialog. As mentioned previously, this functionality was replaced with the introduction of the newer Expression system, which included the more general Measurement Expression function, with the release of NX 3.0. Now even though you are no longer able to create NEW 'Distance Expression' features (you now would use Analysis -> Distance or a Measurement Expression to do the equivalent), you can still edit them if you wish to, reassigning the objects which this feature is referencing (measuring the 'distance' between). Note that if this feature is updated or edited, that Expression 'p312' will update to reflect the new distance.
Anyway, I hope this clears up the mystry. And more importantly, you can leave it there since it will still work and update as expected, just that in the future don't go looking for 'Distance Expressions', but rather use the 'Measurement Expression' instead.
John R. Baker, P.E.
Industry Sector
Cypress, CA
Thanks for the info. This could be useful for me..
Best regards Matsa
