Rebound/Schmidt Hammer
Does anyone have the formula for correcting rebound hammer readings for angle (horiz/vertical)?
When was the last time you drove down the highway without seeing a commercial truck hauling goods?
Download nowINTELLIGENT WORK FORUMS
RE: Rebound/Schmidt Hammer
Vinbridge....without regard to what the manufacturer's scales indicate, the rebound hammer should not be used to determine concrete strength. It is used to determine the consistency of the hardened concrete, which can be used as an indicator to select locations for more accurate testing such as coring for compressive strength.
http:
Again DO NOT use this chart for your hammer!
I also want to share a data sheet for the Standard Method for Rebound Numer of of Handened Concrete as per attached.
Please read ASTM C805-02 for more information for this test using the hammer.
Walt (Structural Engineer)
