How can I get MathCAD to show flux density in units of Guass
I typed in the equation for flux density using cm^2 for the core area and the other units are Volts, Turns and time.
I expect mathCAD to give my answer in either Tesla or Guass.
The answer which it gives is 10^4 times what it should be (if the answer were in Guass) but it doesn't give units.
How can I make MathCAD display the answer in Guass?
Any help would be appreciated. thanks.
RE: How can I get MathCAD to show flux density in units of Guass
TTFN
TTFN
If not, it probably would be best for you to post a worksheet.
Peter
TTFN
Why do you have a 10^8 in the equation? Mathcad understands units, so there should not be any conversion values
TTFN
My mistake was in working with cgs units. The 10^8 is the common formula when working in cgs units but MathCAD works in MKS so this isn't needed; just type in the numbers. Double clicking to the right of the "T" opens the dialog box to replace units with Guass instead of Tesla.
