Allocation Error # 41
I recently ran a non-linear modal time history analysis on a 42 span brigde, for 5 distinct earthquakes, 3 of which are around 40 seconds and two which are around 220 seconds in length. The model ran successfully, but I can only get results for the shorter earthquakes. When I try to get frame results for the longer earthquakes I get the following errors in the log file:
* * * E R R O R * * * (WHILE GETTING FRAME RESPONSE)
COULD NOT ALLOCATE ARRAY NAME = zTimerPTR%rModeHistPT2
ALLOCATE ERROR # 41
Memory available (Allocation failure) = 208MB
INTERNAL PROGRAM ERROR DETECTED. PLEASE RECORD THE FOLLOWING INFORMATION:
VALUES = -6 .000000
MESSAGE = TimerCase_ModesSetModeHistSBR: rModeHistPT2 not allocated
VALUES = 0 .000000
MESSAGE = BinFile_Get: Opening file that is already open (.Y00)
Has anyone had this problem before?
AJ
ALLOCATE ERROR # 41
VALUES = -6 .000000
VALUES = 0 .000000
AJ
