2 - 14 PH Use 2205 or 316L?
I have a carbon steel vessel that is corroded and is to be replaced.
We want to change the materials of construction.
The process is water sparge wash with caustic spray to raise the PH from 2 to 7PH.
However the spray is not finely controlled and the PH has gone as high as14PH.
A 100# steam sparger is used to flash off any Hydrocarbons present to flare.
PH Range 2-14 PH. Chlorides are at 500 PPM. Temperature may be as high as 300 F under sparger. 20 PSIG operating.
Would 316L SS or 2205 perform in this environment?
Dtibodo
Dtibodo
RE: 2 - 14 PH Use 2205 or 316L?
2205 looks like a rational option.
Have you thought of a ferritic stainless? You would have less corrosion resistance but a lot better than with mild steel. An 18% Cr or 18%Cr 2%Mo would be another option.
Plymouth Tube
Cheers,
gr2vessels
They are all low Ni, Mo free, lean duplex grades.
There isn't an option that will be fully corrosion resistant in your application, but these should be good enough to give you reasonable service.
Plymouth Tube
