Easiest method of making an impression of a part
I have a plate with several different size bosses and grooves that I need to make an impression of.  I intend to make a nest for this plate.  What is the easiest way to go about this?  Currently, I sketch the plate using the inverse of the print but I now have the model of the part but don't know exactly how to make an impression.  I believe it's within the combined command??
RE: Easiest method of making an impression of a part
Place the part in an assembly.
Create another part in the assembly that fits over your part.
Use the cavity command to make a cavity of your plate.
Slice up the cavity to suit.
See help for the cavity command.
TOP
CSWP, BSSE
www.engtran.com  www.niswug.org
www.linkedin.com/in/engineeringtransport
Phenom IIx6 1100T = 8GB = FX1400 = XP64SP2 = SW2009SP3
"Node news is good news."
