Inspection Requirements of Fin Fan Coolers
I was asked the other day "what are the inspection requirements for fin fan coolers"? I responded that they were ASME Sec. VIII pressure vessels and the requirements are the same. My question is, Are they considered pipeline components and not subject to the same requirements? Are they subject to the same requirements as pressure vessels? where would I look to find this information? Any help would be appreciated. I am in the field 90% of the time and it has not allowed me to look this up and get the issue taken care of. Any help would be appreciated.
RE: Inspection Requirements of Fin Fan Coolers
I inspect them to API-510 just as if they could be calculated, and give the header-boxes a Tmin of 80% of the original nominal. The finned tubes are essentially imposible to inspect without using IRIS, one slow foot at a time, so they get "benign neglect". We are very lucky that most of our products are pipe preservatives, not agressive in the slightest to stainless steel.
- consequences of failure
- likelihood of failure
- degradation mechanisms
- access requirements
- shutdown philosophy
- regulations applicable to the site
and so on and so forth
Steve Jones
http://www.linkedin.com/pub/8/83b/b04
Overall inspection requirements of the coolers can be found in API 661 which enlists them in a good detail.
Several Client specifications are also a good reference for finding out the inspection requirements.
I hope I'm not too late with the reply :)
